Why haven't I received points for taking part in an equivent?
If you haven't received any points for taking part in an equivent it is most likely because you have not managed to beat your forecast over the course of the equivent.
Why haven't earned any points for taking part in an event with my smart meter?
1) It can take up to 5 days for your points to be awarded
The first thing to remember when taking part in an equivent with your smart meter is that it can take up to 5 days for us to work out how much energy you have helped to save and award your points to your account.
2) You must beat your forecast to earn points
If you have taken part in an equivent via your smart meter, you will only receive points if you have successfully beaten your energy forecast for the duration of the event.
TIP: Your forecast is the amount of electricity you are likely to use at the time of an equivent. It is calculated by taking your average electricity usage during a similar period of time in the previous days from your smart meter data.
Where can I see my forecast?
To view your forecast simply go to the ‘Home’ tab of the equiwatt App during an equivent, there you will be able to see your forecast as shown in the image below:
Where to see your forecast
How can I beat my forecast?
In order to beat your forecast, you will need to use less energy during an equivent. To lower your energy usage try to turn off high energy consumption appliances and avoid turning on appliances when you receive a notification to say that an equivent has started.
TIP: Check your In-home Display (IHD) unit to see how much energy you are using at home to help you work out how much electricity you need to save to beat your forecast.
chameleon_ihd6-png-3
If you believe that you have beaten your forecast but have still not been awarded any points 48 hours after the end of an equivent, please contact us at hello@equiwatt.com so we can investigate the issue for you.
3) We need to receive your energy data to award you points
As well as taking a bit of time for us to calculate your energy savings and therefore your points earnings, sometimes it can take a bit of time for our system to receive your smart meter's energy data from the Smart Meter Network (DCC).
Although we request your smart meter's energy data from the DCC every 20 minutes, occasionally our requests don't succeed and your data is not received. This could be because the smart meter network strength is weak, the meter itself has a bug in it or another reason.
If you have taken part in an equivent and our points are still pending after 48 hours, we suggest trying disconnecting your smart meter from the equiwatt app and reconnecting it again as sometimes this can help the data to be retrieved.
TIP: To disconnect your smart meter from the equiwatt app follow our guide here
However, if your points are still pending after 2 weeks then unfortunately your data cannot be retrieved and we will be unable to award you any points for participating in the event as we have no way to calculate your points or verify that you have successfully beat your forecast.
