Setting up your Phone as a Key - Tesla Model S Instructions
Read the below instructions to set up your phone as a key for your Tesla Model S
Types of Keys
Model S supports the following types of keys:
  • Phone key - You can set up your phone as a "phone key" that communicates with Model S using Bluetooth. A phone key supports automatic locking and unlocking.
  • Key card - Tesla provides two key cards that communicate with Model S using short range radio-frequency identification (RFID) signals. Unlike the phone key and key fobs, the key card does not support automatic locking and unlocking. In situations where your phone key has a dead battery or is lost or stolen, use your key card to unlock, drive, and lock the Model S.
  • Key fob - The key fob (if equipped) allows you to press buttons to open the front and rear trunks and unlock, lock, and drive the Model S. The key fob also supports automatic locking and unlocking, if available in your region (see Walk-Away Door Lock) and can be used as a backup to your phone key.
Model S supports a total of 19 keys, which can include phone keys, key cards, and up to four key fobs.
CAUTION: Remember to bring a key with you when you drive. Although you can drive the Model S away from its key, you will be unable to power it back on after it powers off.
Phone Key
Using your phone as a key is a convenient way to access your Model S. As you approach, your phone's Bluetooth signal is detected and the doors unlock when you press a door handle. Likewise, when you exit and walk away with the phone key, doors automatically lock (provided the Walk-Away Door Lock feature is turned on; see Walk-Away Door Lock).
CAUTION: Do not leave your paired phone in your vehicle (for example, if you are hiking or at the beach). If you must leave your phone in the vehicle, disable Bluetooth and/or turn the phone off.
Before you can use a phone to access Model S, follow these steps to authenticate it (see Pairing a New Phone Key).
Once a phone has been authenticated, it no longer requires an internet connection to be used as a phone key for Model S. However, to use the phone hands-free, access your phone's contacts, play media from it, etc., you must also pair it and connect it as a Bluetooth device (see Bluetooth).
To view a list of keys that can currently access Model S, or to remove a phone key, touch Controls > Locks (see Managing Keys).
Model S can connect to three phone keys simultaneously. Therefore, if more than three phone keys are detected and you want to authenticate or pair a different phone, move the other connected phone key(s) out of range or turn off its Bluetooth setting.
Some smartphones with NFC capability can be used to lock/unlock your vehicle, just like using a key card. Ensure the Tesla mobile app is correctly paired to your vehicle and enable the NFC function on your phone. Once enabled, simply hold the phone to the driver's side door pillar to lock or unlock the door. Refer to your smartphone's instructions for specific information on how to do this.
Key Card
Tesla provides you with two Model S key cards, designed to fit in your wallet.
To use a key card to unlock or lock Model S, position the card as shown and tap it against the card reader located approximately one third the way up of the driver's side door pillar. When Model S detects the key card, the exterior lights flash, the mirrors unfold or fold (if Fold Mirrors is on), the horn sounds (if Lock Confirmation Sound is on), and the doors unlock or lock.
PLEASE NOTE: You may need to physically touch the wireless phone charger or driver's side door pillar with the key card, and you may need to hold it against the transmitter for one or two seconds.
e05e63c0-62ee-42f4-b044-c8566137b4d7
Once inside, power up Model S by pressing the brake pedal within two minutes of scanning the key card (see Starting and Powering Off). If you wait longer than two minutes, you must re-authenticate by placing the key card near the card reader located in the wireless phone charger on the center console. When your key card is detected, your two minute authentication period restarts.
d59d623b-aa96-4f45-8f53-8fad55e2972c
PLEASE NOTE: If enabled, Walk-Away Door Lock (see Walk-Away Door Lock) operates only when you walk away using a phone key or passive key fob. When you walk away carrying your key card, the Model S does not automatically unlock/lock.
Key Fob
You can quickly familiarise yourself with the key fob by thinking of it as a miniature version of the Model S, with the Tesla badge representing the front. The key has buttons that feel like softer areas on the surface.
PLEASE NOTE: Depending on the market region, vehicle configuration, or date of manufacture, your vehicle may not come with a key fob. Go to http://shop.tesla.com for more information.
f434a20f-e8f9-4c17-934d-04568e3567f5
1) Rear trunk - Double-click to open or close the rear trunk. Hold down for one to two seconds to open the charge port door.
2) Lock/Unlock All - Single-click to lock doors and trunks (all doors and trunks must be closed). Double-click to unlock doors and trunks.
3) Front trunk - Double-click to unlatch the front trunk.
Once inside, power up Model S by pressing the brake pedal within two minutes of pressing the unlock button on the key fob (see Starting and Powering Off). If you wait longer than two minutes, you must press the unlock button again, or place the key fob near the card reader located in the lower half of the left wireless phone charger, facing downward, on the center console. When your key fob is detected, the two minute authentication period restarts.
When approaching or leaving Model S carrying the key fob, you do not need to point the key fob at Model S as you press a button, but you must be within operating range.
Radio equipment on a similar frequency can affect the key. If this happens, move the key at least 30 cm away from other electronic devices (phones, laptops, etc.).
In the event that the key fob's battery is dead, you can still use it. To unlock the vehicle, scan the key fob on the card reader located on the driver's side door pillar (like the key card).
2bbc7b7e-e6fa-42d1-8ba0-df68cf22b728
To drive the vehicle, scan the key fob on the phone charger.
  1. Place it at the top of the left phone charger, against the center divider.
  2. Point the front of the key fob down.
  3. Swipe downwards.
f9b87a81-4c60-4a1c-880f-e846850d6fc9
Instructions for changing the battery are provided in Replacing the Key Fob Battery.
PLEASE NOTE: You can use the same key fob with multiple Model S vehicles provided you authenticate it (see Managing Keys). However, the key fob works with only one Model S at a time. Therefore, to use a key fob for a different Model S, touch its flat side against the card reader on the driver's side door pillar.
Model S supports up to four different key fobs.
CAUTION: Protect the key from impact, high temperatures, and damage from liquids. Avoid contact with solvents, waxes, and abrasive cleaners.
Passive Locking and Unlocking
Locking and unlocking Model S with your key fob is conveniently hands-free. Although you must be carrying a paired key fob, there is no need to use it. Model S has sensors around the vehicle that can recognise the presence of a key fob within a range of approximately two meters. Therefore, you can keep your key fob in your pocket or purse and press the door handle to unlock and extend the handle. When carrying your key fob with you, you can also open the trunk without having to use the key by pressing the liftgate's exterior switch. If Walk-Away Door Lock is enabled, Model S automatically locks when you exit and the key fob is no longer in range (see Walk-Away Door Lock). Passive locking and unlocking is automatically enabled when you pair your key fob to Model S.
Although you can use the same key fob with multiple vehicles, it can only be paired to one vehicle at a time. To activate a paired key fob to a different vehicle, touch the flat side onto the driver's side door pillar and click any button on the key fob to confirm.
PLEASE NOTE: For increased security, passive locking and unlocking disables after being stationary for five minutes while within vehicle range when the vehicle is not in use (for example, you are standing outside your vehicle). In this situation, you must shake or press a button on the key fob to re-enable passive locking and unlocking.
Under normal use, the key fob has a battery that lasts for up to one year, depending on key fob version and selected vehicle settings. When the battery is low, a message displays on the touchscreen.
To replace the key fob battery:
1) With the key fob placed button side down on a soft surface, release the bottom cover, using a small flat-bladed tool.
2) Remove the battery by lifting it away from the retaining clips.
3) While avoiding touching the battery's flat surfaces, insert the new battery (type CR2330) with the ‘+’ side facing up.
PLEASE NOTE: Wipe the battery clean before fitting and avoid touching the battery's flat surfaces. Finger marks on the flat surfaces of the battery can reduce battery life.
CR2330 batteries can be purchased from any retailer that sells batteries.
4) Holding the bottom cover at an angle, align the tabs on the cover with the corresponding slots on the key fob, then press the cover firmly onto the key fob until it snaps into place.
5) Test that the key fob works by unlocking and locking Model S.
77438a49-b8df-4bb8-ac41-af69a8baa272
91055286-3c7d-45f1-a99b-1ae800b0fada
WARNING: Key fob batteries contain a chemical burn hazard and should not be ingested. The key fob contains a coin cell battery. If the coin cell battery is swallowed, it can cause severe internal burns within two hours and can lead to death. Keep new and used batteries away from children. If the battery compartment does not close securely, stop using the product and keep it away from children. If you think batteries might have been swallowed or placed inside any part of the body, seek immediate medical attention.
Managing Keys
To display a list of all keys that can access your Model S, touch Controls > Locks. An icon displays next to each key to indicate whether the key is a phone key, key card, or key fob. Use this list to manage keys that have access to your Model S.
Model S supports up to 19 keys. When you reach this limit, you must delete a key before adding a new one.
PLEASE NOTE: You can use the same key for more than one Model S. This prevents you from having to deal with multiple keys when you switch vehicles. If you customise the name of an authenticated key card or key fob on one Model S (by touching the pencil icon), any other Model S to which the key card or key fob is authenticated also displays the changed name.
If you are leasing your vehicle, contact your leasing company to add or remove keys.
To set up your smartphone as a key:
1) Download the Tesla mobile app to your phone.
2) Log into the Tesla mobile app using your Tesla account username and password.
PLEASE NOTE: You must remain logged in to your Tesla account to use your phone to access Model S.
If multiple vehicles are linked to your Tesla account, you must ensure that the vehicle you want the mobile app to access is currently selected on the mobile app.
3) Ensure:
  • Your phone's general Bluetooth settings are enabled.
  • Bluetooth is enabled within your phone's settings for the Tesla mobile app. For example, on your phone, navigate to Settings, choose the Tesla mobile app, and ensure the Bluetooth setting is turned on.
  • Access to your location is enabled. Open the Tesla mobile app in your phone's settings and select Location > Always. For the best experience, keep the mobile app running in the background.
  • Allow Mobile Access is enabled on the vehicle touchscreen (Controls > Safety > Allow Mobile Access).
PLEASE NOTE: Model S communicates with your phone using Bluetooth. Keep in mind that your phone must have enough battery power to run Bluetooth and that many phones disable Bluetooth when the battery is low.
4) While inside or near the vehicle, open the Tesla mobile app and touch Set Up Phone Key on the main screen, or navigate to Security > Set Up Phone Key. Follow the prompts on the mobile app and vehicle touchscreen to set up your phone key.
Adding Keys from the Touchscreen
If you have a key card or key fob that is already paired with your vehicle, you can pair a new key using the touchscreen.
bbe6ab50-01d9-4fba-b855-0d61b628bdc1
1) On the touchscreen, touch Controls > Locks > Keys > Add Key.
2) Scan your new key card or key fob on the card reader located on the wireless phone charger. To scan the key fob:
  • Place it at the top of the left phone charger, against the center divider.
  • Point the front of the key fob down.
  • Swipe downwards (as shown in the image).
When you hear a chime and the new key is recognised, remove it from the card reader.
3) Scan a key card or key fob that has already been paired to the vehicle to confirm new key pairing.
4) When complete, the key list includes the new key. Touch the associated pencil icon to customise the name of the key.
Adding Keys from the Mobile App
In the event that you don't have a working key card or key fob, you can add a new key using the Tesla mobile app.
PLEASE NOTE: Only the owner of the vehicle can pair a new key using the mobile app.
Pairing a key with the mobile app is supported with version 4.29.0 of the Tesla mobile app on vehicles with software versions 2022.40 or higher.
1) While inside or near the vehicle, open the Tesla mobile app on your smartphone.
2) In the mobile app, touch Security & Drivers, then touch Add Key Card.
3) Scan your new key card or key fob on the card reader located on the wireless phone charger. To scan the key fob:
4) When the key is paired successfully, the mobile app shows a confirmation message. Touch Done in the mobile app and remove the key card or key fob from the card reader.
5) When complete, the key list on the touchscreen includes the new key. Touch the associated pencil icon to customise the name of the key.
Removing Keys
When you no longer want a key to access Model S (for example, you lost your phone or key card, etc.), follow these steps to remove it.
  1. On the touchscreen, touch Controls > Locks.
  2. In the key list, find the key that you would like to delete and touch its associated trash icon.
  3. When prompted, scan an authenticated key on the card reader to confirm the deletion. When complete, the key list no longer includes the deleted key.
PLEASE NOTE: Model S requires at least one authenticated key card or key fob at all times. If only one key card remains on the key list, you cannot delete it.
Replacing Key cards
If you lose a key card, you can purchase replacement ones on the Tesla Shop. When ready to pair, simply follow the steps in Managing Keys. Remember to remove your old key cards from Controls > Locks > Keys for security purposes.
